Presentazione
Discussione in 'Mi presento.... io e la mia BMW' iniziata da RandyEastman, 2 Novembre 2022.
  1. RandyEastman
    RandyEastman Aspirante Pilota
    11 Luglio 2022
    LA
    BMW
    How to Sew a Tie: A Step-by-Step Guide for Beginners
    Making a tie is a satisfying project for both novice and seasoned sewers. Learning to sew a tie is a creative and exciting project, whether your goal is to make a one-of-a-kind personlized gift or an adorable accessory for yourself. You'll learn how to sew your tie in this step-by-step tutorial.
    For more helpful sewing guides and top product reviews, you can visit CraftsSelection.com. We create sewing product buying guides to help you find the best products for your sewing needs. Our sewing product buying guides are based on our expertise and experience of many years sewing and crafting, so you can be sure you're getting the best practical advice. Visit [​IMG] CraftsSelection and find the best affordable sewing supplies for your projects.
    Materials Needed
    - Fabric
    - Interfacing (Interlining)
    - Sewing Supplies (needles, threads, scissors, etc.)
    - Sewing Machine (optional)
    - Tie Pattern
    How to Sew a Tie: Step-by-Step Instructions
    Now that you have your materials ready, let's proceed with sewing your tie:
    Cut Your Fabrics
    - Start by laying out your preferred main fabric on your workspace. This fabric will serve as the outer layer of your tie.
    - Put the pieces of your tie pattern on top of the fabric.
    - Mark the outlines of the pattern pieces using the tailor's chalk and pin them into place.
    - Follow the marked lines when carefully cutting the fabric pieces.
    - Utilizing the same pattern, repeat this procedure with your lining and interfacing fabrics.
    Sew the Tie Fabric Pieces Together
    Sew the main tie fabric pieces together to form a long strip. The front of the tie will be made up of this strip.
    ➳➳➳ See Also: [​IMG] Find The Best Product For Crafts Projects at CraftsSelection
    Add the Lining to the End of the Tie
    - Attach the small lining to the back of the tie (the tie's wrong side) after sewing the main tie pieces together.
    - Leave the edges of the pieces with a seam allowance of roughly 1/4 inch.
    - When the tie is finished, turn it right-side out and carefully iron the edges to give it a polished appearance.
    Add Interfacing Down the Center of the Tie
    - The interfacing should run down the length of the tie, with its tip fitting into the pocket created for the tipping lining.
    - To hide the interfacing, fold the tie's sides over it.
    - Pin the folded edges together to keep them in place.
    - Hand-sew the folded edges to finish the tie using a slip stitch.
    - To finish, use an iron to smooth the seams and give your tie a tidy, professional look.
    Finding the right sewing products can be daunting, so Crafts Selection is here to help. Our reviews of best products are thorough and unbiased, so you can trust that you're getting the most accurate information possible.
    ✩✩✩ See This Page: [​IMG] Best Products Picked For You CraftsSelection.com
    Conclusion
    You will have successfully sewn your tie once you have followed this guide until the end. Making a tie is rewarding and enjoyable, regardless of your sewing skills. Your office attire could use a fresh set of hand-sewn ties.
    Ultima modifica: 29 Settembre 2023
    A Bmw_pugliese e wewwo piace questo messaggio.
  2. wewwo
    wewwo
    28.380
    4.616
    19 Febbraio 2016
    Mediolanum
    Nel caso non lo avessi già fatto, ti consiglio di leggere il nostro Regolamento e le Condizioni di Utilizzo del sito. Esserne coscienti è molto importante!
    • Infine, dato che siamo tutti dei curiosoni, vogliamo vedere la tua auto; ti consiglio di dare un'occhiata a questo tutorial se vuoi inserire immagini nel forum. Si raccomanda di prestare attenzione alle dimensioni delle immagini: max 800x600 prima di inserirle dovrai ridimensionarle, se non sei capace oppure sei poco pratico, abbiamo un comodo tutorial anche per questo scopo.
    Vedrai che troverai nella nostra community l'ambiente ideale per condividere la tua passione per il marchio BMW - MINI, ricevere aiuto e darlo.
    Ogni giorno potrai tenerti informato sulle novità del mondo BMW - MINI e dell'auto in generale: consulta le notizie in home page e sarai sempre al corrente delle news!
    Abbiamo anche una pagina Facebook (link) ti invitiamo a visitarla e cliccare su "Mi piace" :mrgreen:
    Per qualsiasi aiuto o interrogativo interpella un Moderatore, sarà lieto di poterti aiutare ;)
  3. Bmw_pugliese
    6.430
    3.379
    11 Febbraio 2018
    Martina Franca
    BMW E60 525D
    Benvenuto
