ECCO LE PROVE RIFATEVI GLI OCCHI. http://www.youtube.com/watch?v=ZL7T9BD_Q3k&eurl=http://www.autoblog.it/
Certo che lo sò, compressore volumetrico e più di 500cv, freni buoni, assetto paura il tutto alleggerito al massimo.
COsa!!! l'unica modifica è l'aspirazione e il volumetrico vortec. gli scarichi ha i SS freni AP sosp. KW. Non mi sembra così stravolta
beh insomma io direi che gli han dato una bella lavorata RWHP: 532,71 / 0.85bar / 98 oktan fuel Torque: 483,67 / 0.85bar / 98 oktan fuel Suspension: KW 3-way adjustable race kit Chassie: adjustable front camber plates front springs 120 mm + helper rear springs 100 mm + helper prepared front wishbones excentric caster bearing kit 3-way adjustable anti-rollbar + uniball thrust-rods stiffer rear frame, changed kinematic points aluminium bushings (frame) aluminium bushings (final drive cover) excenter uniball bearings (camber) center uniball bearings (tow) center uniball bearings (top arm outside) stiffer rubber bearing top arm inside aluminium machined lower arm + uniball bearings 2-way adjustable anti-rollbar + thrust rods prepaired drive shafts + vent system Frontbrakes: AP 6 pot caliper, PFC 355 mm Ø disc, PFC 01 race pads INOX brake line system, brake vent system 80 mm Ø. Rearbrakes: AP 4 pot caliper, PFC 323 mm Ø disc, carbon race pads, INOX brake line system Frontwheels: BBS GT split, F18"x10 ET 40, 15 mm spacerdiscs, Tiresize 265/35/18” Rearwheels: BBS GT split R18"x11 ET 35, 12 mm spacerdiscs, Tiresize 295/30/18" Tires: Michelin pilot Sport Cup R tires Rims: BBS Racing 18" Sandmold magnesium center with forge aluminium lane Exhaust: Supersprint lightweight racing all the way. Spec: 100% Stainless exhaust system, Oversize 2x Ø 60 mm -Manifold. (LHD) -Front pipes kit. -Replaces Kat. -Centre exhaust. 76mm LIGHTWEIGHT RACING EXHAUST -LIGHTWEIGHT RACING EXHAUST Rear exhaust OO 80 R. + OO 80 L Drive train/clutch: 3:91 ratio differential, Sachs Sinterclutch kit. Exterior: Carbon fibre roof, hood, trunk, fenders, front and diffusor. Interior: bolted rollcage light version (25 kg), adjustable Recaro race seat system with 6 points harness. A lot of carbon fibre interior as standard CSL
Quando ve l'avevo detto io non ci credevate?? http://www.bmwpassion.com/forum/showthread.php?t=112938
