Z4M Coupè Racing Kit
Discussione in 'BMW Z in generale' iniziata da El Nino, 1 Marzo 2006.
  1. El Nino
    18.476
    431
    23 Maggio 2003
    da www.supercars.net
    Unveiling in Geneva: On the occasion of the Automobilsalon, Prof Dr
    Burkhard Göschel, BMW Group Board Member Purchasing and Development,
    introduced a new racing car for customer motor racing.
    The Motorsport Version of the BMW Z4 M Coupé, which has already made a
    big impression as a production model, is the first two-seater BMW
    Motorsport offers for customer teams. When it came to the development,
    BMW faced a huge challenge: The car had to have what is needed to race
    successfully on the world's most demanding and spectacular racetrack,
    the Nürburgring's famous Nordschleife. The new motorsport coupé can be
    used by private BMW customer teams in the German Endurance
    Championship and in the Nürburgring 24-Hour Race.
    The power unit of the beefy coupé is a BMW Motorsport designed
    3.2-litre in-line 6-cylinder engine delivering about 400bhp, with the
    suspension area in particular benefiting from the knowledge gained
    from the successful BMW M3 GTR project. With its varied component
    ranges, BMW Motorsport and BMW Racing Parts Distribution offer
    customer teams a new technology platform for use in many miscellaneous
    international racing and club sport series, with the Nordschleife
    enthusiasts not being the only interested party, as the coupé also
    represents the perfect car for use in the Belgian Belcar series and
    other, non-European, endurance series.
    The kit can be ordered from May 2006 at BMW Motorsport and will be
    available for an estimated ? 250,000 (plus VAT).
    Technical Data BMW Z4 M Coupé Motorsport Version
    Length: 4415 mm
    Width: 1880 mm
    Wheelbase: 2493 mm
    Front & Rear Overhang: 865 mm/774mm
    Rear Wing Width: 1504 mm
    Front & Rear Ground Clearance: 80 mm/90 mm
    Front & Rear Tyres: Michelin 27/65-18, 28/71-18
    Front Brake: Grey cast iron disc dia. 380 mm / 6 pot fixed calliper
    Rear Brake: Grey cast iron disc dia. 320 mm / 4 pot fixed calliper
    Drive Line: sequential 6-speed gearbox, sintered clutch
    Engine Layout: six cylinder in line
    Cylinder Capacity: 3246 cc
    Bore x Stroke: 87 x 91 mm
    Compression Ratio: 12,5:1
    Max. Power: approx. 400 PS at 8200 rpm
    Max. Torque: approx. 400 Nm at approx. 5750 rpm
    Max. Revolutions per minute: 8400 rpm
    Cylinder block: one-piece construction
    Crankshaft: forged steel part
    Piston: forged slipper skirt piston
    Con-rod: Steel
    Cylinder head: Aluminium, four valves per cylinder
    Valve train: Two chain driven overhead camshafts with variable valve
    timing
    Intake System: Six single throttle valves, Carbon fibre Air box with
    resonance induction optimised inlet pipes
    Exhaust System: Multiple pipe manifold with silencer and catalytic
    converter
    Lubricating System: Wet Sump Lubrication
    Cooling System: Water / Air cooler
    Flywheel: Steel
    Fuel System: Inlet-Pipe Injection, one Injector per Cylinder, 5 bar
    injection pressure
    Fuel: 5-star lead-free petrol, ROZ min=98
    Fuel Tank Volume: 120 litres
    Minimum Weight: 1200 kg in Nürburgring Specification
    Engine Management System: BMW Motorsport ECU406 with two powerful
    microprocessors, Ethernet Interface and four CAN busses; Cylinder
    selective optimized Injection and Ignition; Pit-Speed-Limiter;
    Quick-Shift; Engine Log Book; Electronic Throttle Control; VANOS
    Control; Race ABS; Traction Control.
    Energy Management: Distribution and Control of the electric energy
    through the BMW Motorsport POWER400 Control Unit; Networking of all
    Sensors and Actuators through a CAN Bus.
    Electric loom: Weight optimised
    Ignition coils: Six high performance pencil-type ignition coils with
    integrated ignition driver.
    Sparkplugs: NGK high performance Sparkplugs
    Instruments: Free programmable LCD Display with integrated shift
    lights
    Steering-wheel: multiple function Steering-wheel with Quick-Release
    mechanism and display control
  2. RossoCorsa
    RossoCorsa
    12.937
    773
    14 Novembre 2002
    BMW 330Ci + (ex) X6 40d
    PODEROSA!!! :eek:
  3. 996GT3
    20.667
    863
    11 Novembre 2005
    330i E91 Attiva, Mini One D
    STUPENDA!!!!!!! Come la vorrei stradale!
    E poi il bianco... come son contento che tra qualche settimana mi arriverà un'altra macchina bianca dopo tanti argento e colori scuri! =P~
  4. Luca318
    16.574
    116
    20 Novembre 2003
    ///M3 E36 Individual
