Z3 M Turbo
Discussione in 'BMW Z in generale' iniziata da M3 Motorsport Power, 21 Febbraio 2005.
  1. M3 Motorsport Power
    5.702
    103
    7 Gennaio 2005
    Girando in rete ho trovato questo bel mostriciattolo, una Z3 M turbo con 600cv alla ruota.
    Ecco le caratteristiche tecniche:
    Specification:
    0-60mph: 3.6 sec
    0-100mph: under 7.4 sec (estimated with smoking tires)
    1/4 mile: 11.6 sec / 131 mph
    Horsepower: 726.00 BHP at flywheel @ 21 psi
    Fuel: 93 octane (pump gasoline super unleaded)
    Engine:
    1999 S52 fully bulit engine. JE Pistons / Pauter rods
    AA Turbo spec camshafts
    Turbo Kit:
    AA custom intercooler 1300 CFM with air deflector 12.9x3.5x20 core 2.5" in/out
    AA custom auxillary fan
    Garrett GT40R Turbocharger
    AA turbo manifold with external wastegate upgrade
    HKS GTII 50mm racing wastegate
    Greddy oil catchcan
    HKS racing bypass valve
    AA constant torque hoseclamps
    AA custom 4.0" intake plumbing to turbo
    K&N Air filter with low pick-up intake
    Kevlar thermal wrap on all turbo plumbing
    Intake manifold thermal wrapped
    AA custom software/dyno tuned
    Additional Cooling:
    AA custom aluminum radiator
    AA custom water/alcohol injection system with (2)
    accumulators
    AA custom water/alcohol reservoir with thermal wrap
    AA dual water/alcohol injector nozzles
    Instruments:
    Stock instruments
    Custom boost gauge with chrome ring replaced clock
    Greddy Turbo timer
    Greddy electronic boost controller
    Lean/Rich mixture gauge
    Oil Temperature gauge
    Fuel:
    Custom 14mm I.D. fuel hose (stock = 7.5mm)
    Custom 1000 HP fuel pump
    Custom hi-flow fuel filters
    AA custom dead-end fuel rail
    AA custom 550cc fuel injectors
    AA custom external fuel pressure regulator with liquid filled gauge
    Ignition:
    AEM ignition module / iridium plugs
    Traction Control:
    Racelogic
    Exhaust:
    AA custom 3.0" exhaust with dual 3.0" resonators
    (4) 3.5" exhaust tips
    Clutch:
    Sachs 4 puck metal race clutch
    AA GEN3 Aluminum 12.0 Lb Flywheel
    Differential:
    AA Custom 40% lock up with 2.79:1 ratio
    Shifter:
    AA Short Shifter Level 4 kit with AA Tuning Knob
    Suspension:
    Eibacjh Race springs 550lbs front 700 lbs rear
    Ground Control adjustable camber/caster plates
    Adjustable Koni shocks
    Factory swaybars
    Wheels/Tires:
    Kinesis K58
    (F)18x8.5
    (R)18x11
    Michelin Pilot Sport
    (F) 235/40ZR18
    (R) 315/30ZR18
    Brakes:
    Front-Brembo gas/slotted 355x32 on 2 piece hat with Brembo 4 piston caliper
    Rear -Brembo gas/slotted on 2 piece hat with Brembo 4 piston calipers
    Ci sono anche due video:
    See a AA tuned 726HP ZM3 Turbo
    with 10% Racelogic Traction Control
    with Racelogic Traction Control in DRY Conditions
  2. Dagos
    Dagos Primo Pilota
    1.431
    18 Giugno 2004
    Porsche 996 4S
    ...sono un po shokkato, 726 cavalli sono veramente una esagerazione adrenalinica :mrgreen:
