Ufficiale: Subaru Impreza IV 2016 | BMWpassion forum e blog
Discussione in 'Auto Giapponesi e Asiatiche' iniziata da beckervdo, 23 Marzo 2016.
  1. beckervdo
    4.446
    Kia Sportage HEV 2023
  2. Gabo
    5.500
    non riescono proprio a far na robetta attraente
    dopo la filante STi '07 solo cubi viaggianti
  3. giacomo
    13.866
    958
    4 Marzo 2004
    Renault Clio
    tempo fa avevano mostrato un prototipo dalle linee stupende, ma evidentemente non vogliono "strafare", mah
  4. actarus8v
    50.710
    5.224
    se la facevano bella era strano :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  5. magnabuffi
    06
  6. giacomo
    13.866
    958
    4 Marzo 2004
    Renault Clio
    The S209 is not technically a Subaru model. Because of the extensive mechanical work necessary to create the model, the company actually homologates it as an STI in the United States, rather than a Subie.
    STI thoroughly overhauls the engine to push the engine output so high. An HKS turbo replaces the standard part, and the upgraded unit packs a larger turbine and compressor. The setup also allows for maximum boost of 18 psi instead the normal 16.2 psi. Inside the powerplant, there are forged pistons and connecting rods that are stronger and reduce rotating mass. The intake system has revised ducting, and a control on the steering wheel activates the intercooler water spray. A high-flow fuel pump, larger injectors cope with the tuned engine's greater need for gasoline. Hand-polished headers provide a shine under the hood. To get rid of the bad air, a new exhaust has 17-percent less resistance and weighs just 4.1 pounds.
    The only available gearbox is a six-speed manual that routes to Subie's famous all-wheel-drive system. STI recalibrates the driving modes to reflect the drivetrain revisions, though.
    The S209 reflects its increased power on the outside through a heavily revised body kit. It adds wider fenders that broaden the body by 1.7 inches (43.2 millimeters) over a standard WRX STI. The extra width lets STI expand the front and rear track by 0.6 inches (15.2 mm). For even more grip, the performance division then covers the 19-inch BBS forged wheels with a set of 265/35 Dunlop GT600A summer-only tires. Dunlop specifically developed this rubber for the S209 so that the sedan was able to offer over 1.0 g of lateral grip.
    As a further handling aid, STI gets serious about the S209's suspension. It rides on a set of Bilstein dampers, with stiffer springs and a 20-mm rear stabilizer bar. A flexible front strut tower bar and front/rear draw stiffeners add extra rigidity to the body.
    When the time eventually comes to slow down, the S209 has a set of Brembo brakes comprising cross-drilled rotors, 6-piston front calipers, two-piston rear calipers, and high-friction pads.
    There are some very minor tweaks to the S209's interior. Drivers grip a flat-bottom steering wheel with Ultrasuede upholstery. Occupants in front sit in thickly bolstered Recaro seats with silver center inserts.
    The S209 will go on sale in late 2019. Subaru will announce the price closer to launch, although hardcore Subie fans will likely pay whatever the company will ask to own the most hardcore STI ever in the United States.
    Source: Subaru
  7. huskywr240
    20.703
    1.378
    8 Marzo 2011
    LV-223
    A prima impressione mi sembra troppo imborghesita come design, meno aggressiva delle precedenti.
    Le precedenti mi sembravano anche meno alte da terra
  8. LupoTHP
    4.608
    1.445
    18 Dicembre 2013
    MX5 ND sport
  9. huskywr240
    20.703
    1.378
    8 Marzo 2011
    LV-223
