Ufficiale: Ferrari F12 TDF | BMWpassion forum e blog
Discussione in 'Auto Europee' iniziata da beckervdo, 13 Ottobre 2015.
  1. beckervdo
    4.447
    Kia Sportage HEV 2023
    carscoops
    Press Release:
    Maranello, 13 October 2015 – Ferrari reveals the F12tdf which pays homage to the Tour de France, the legendary endurance road race that Ferrari dominated in the 1950s and ‘60s, particularly with the 1956 250 GT Berlinetta which won four consecutive editions. It was a race that rewarded cars that combined maximum performance with the driveability and ease of use that enabled the competitors to race for hundreds of kilometres a day over fast, tortuous roads and on circuits. The F12tdf is the ultimate expression of the concept of an extreme road car that is equally at home on the track, and just 799 will be built.The F12tdf is a concentration of technical innovations which involve all those areas central to Ferrari’s DNA: engine, aerodynamics and vehicle dynamics. As a result, in terms of acceleration, roadholding and agility, the new berlinetta is second to none.
    The F12tdf’s performance is assured by the 780 cv, naturally-aspirated V12 derived directly from the F12berlinetta’s multi-award-winning engine. The car’s exhilarating dynamic behaviour, specifically its lateral acceleration in corners, is due to an 8% increase in the ratio of the front tyres compared to the rear ones. The car’s natural tendency to oversteer as a result of the change in tyre sizes is compensated for by the innovative rear-wheel steering system – known as the Virtual Short Wheelbase, which is integrated with the other vehicle dynamic control systems – that guarantees the steering wheel response times and turn-in of a competition car while increasing stability at high speed. Cornering speeds are also higher thanks to the significant increase in downforce - +87% - which has reached unprecedented levels for a front-engined V12 berlinetta.
    A radical redesign of the bodywork, interior, engine, transmission and running gear, along with the abundant use of carbon-fibre inside and out, has slashed 110 kg off the car’s overall weight.
    All of these factors combine to produce record performance figures: 0-100 km/h in 2.9 seconds and 0-200 km/h in 7.9 seconds in addition to a substantial boost in lateral acceleration. The F12tdf laps Fiorano in just 1’21”.
    Outstanding stopping distances are guaranteed by the adoption of the new Extreme Design one-piece brake callipers already seen on the LaFerrari. This new-generation system means the car can brake from 100-0 km/h in just 30.5 m and from 200-0 in 121 m.
    POWERTRAIN
    The engine is the F12berlinetta’s 6262cc 65° V12 on which Ferrari engineers worked to boost maximum power output from 740 cv to 780 cv at 8,500 rpm, yielding a specific power output of 125 cv/l. The engine’s sporty response is assured by a maximum torque figure of 705 Nm (up from 690 Nm) at 6,750 rpm with 80% already available at 2,500 rpm, resulting in unparalleled, progressive pick-up all the way to the red-line at 8,900 rpm.
    Numerous modifications have been developed for this engine, starting with the use of race-inspired mechanical tappets and variable-geometry intake trumpets used on Formula 1 cars which help boost volumetric efficiency at high revs.
    The F12tdf is equipped with a specific version of the F1 DCT with 6% shorter gear ratios that delivers 30% faster upshifts and 40% faster downshifts.
    VEHICLE DYNAMICS
    Ferrari’s engineers sought to create an extremely agile and powerful car which could also be driven by less expert drivers. They drew on the wealth of experience built up in the XX programmes which are dedicated to developing extremely high performance cars driven by non-professional drivers.
    Extraordinary chassis dynamics, in terms of maximum lateral acceleration and responsiveness, are in part achieved by the increase in the front tyre dimensions, which jump from 255 to 275, along with the front channel size - up from 9.5” to 10”. This modification guarantees higher lateral acceleration generated by the front axle but, alone, this would have caused oversteer on the limit, making the car more challenging for less expert drivers.
    To enable even gentlemen drivers to make full use of the performance, Ferrari developed its new Virtual Short Wheelbase system. Debuting on the F12tdf, the rear axle is active, allowing the rear wheels to pivot around a vertical axis.
    Using model-based control logic developed entirely in-house by Ferrari, the rear axle steering automatically adjusts the rear wheels, working out the optimal steering angle as a function of the steering wheel angle, speed of steering inputs and vehicle speed.
    The Virtual Short Wheelbase improves the car’s responsiveness to make it feel more agile, with instantaneous turn-in that can be best appreciated on twisty roads and on more technically challenging tracks while, at the same time, improving stability at high speeds.
    AERODYNAMICS
    The F12tdf’s aerodynamic performance is nothing short of record-breaking – its aerodynamic efficiency figure is 1.6, almost double that of the F12berlinetta. Downforce is 230 kg at 200 km/h, which is an impressive 107 kg more.
    Development affected every area of the car’s surface, producing striking elements that lend its forms a unique sleek power. At the front, a highly complex bumper contributes to downforce generation. It features a radically scooped lower section and incorporates a competition car-inspired splitter, dive planes, floor wings and louvres to boost the efficiency of both the sides and the underbody.
    The Aerobridge on the car’s front flank has been redesigned to increase the energising effect of the air flow along the top of the sides, while at the rear, louvres on the wheelarch create a depression that extracts air from the inner wheelarch, thereby increasing the efficiency of a section of the underbody that is usually little used in generating downforce.
    The rear spoiler is now 60mm longer and 30mm higher, while the rake of the rear screen has been made more vertical to extend the surface area over which the spoiler can generate downforce and to capitalise on its advantages more effectively. The concave curvature of the rear luggage hatch either side of the rear screen further enhances the solution.
    Three pairs of GT-racing-derived strakes have been adopted on the aerodynamic underbody and are responsible for 30% of the increase in downforce compared to the F12berlinetta. The rear diffuser has been completely redesigned and now sports a system of three active flaps. It has been split into three channels and features curved fences and vertical splitters to boost the power of the vortexes and enhance the expansion of the flow in the horizontal plane. This radical aerodynamic design work essentially created a whole new car that also marks a major stylistic departure from the F12berlinetta.
    STYLING
    Designed by the Ferrari Styling Centre, the new F12tdf has particularly imposing yet sensual forms, the product of Ferrari’s continuous commitment to melding sculptural beauty with functional demands.
    All of the bodywork panels, from the chiselled nose to the tail, have been revised. Wider front and rear tracks also give the car an even more aggressive stance.
    In terms of the formal design language, the objective was to create a sophisticated interaction between the sculptural surfaces of the F12berlinetta and a more graphic treatment of the various new aerodynamic features. The best testament to this intent is the evolution of the Aerobridge, the design of which is further enhanced by the use of bare carbon-fibre. Developed in such a technical manner, this component combines with the other details in creating a coherent aesthetic approach to the whole car.
    The car’s uncompromising sportiness is expressed with the same degree of purity in the deliberately Spartan cockpit. The wrap-around effect that embraces the driving position is intensified by the use of carbon-fibre housings for the instruments and satellite pods. The door panels have been pared back to a single carbon-fibre shell, while the glove compartment has disappeared to be replaced by simple knee padding. Alcantara rather the traditional leather was chosen for the cabin trim, technical fabric for the seats and patterned aluminium instead of mats for the floor, once again with the aim of saving every last ounce of weight.
    The F12tdf’s specification is completed by lightweight alloys with five twinned spokes that are designed to have the narrowest section possible to reduce unsprung weight.
    Text and images of the F12tdf can be downloaded from the Ferrari media site: www.media.ferrari.com
    F12tdf Technical Specifications
    Engine
    [TABLE="class: cms_table_noborder, width: 382"]
    [TR]
    [TD]Type[/TD]
    [TD]65-degree V12[/TD]
    [/TR]
    [TR]
    [TD]Overall displacement[/TD]
    [TD]6,262 cc[/TD]
    [/TR]
    [TR]
    [TD]Max. power output*[/TD]
    [TD]574 kW (780 cv) at 8,500 rpm[/TD]
    [/TR]
    [TR]
    [TD]Max. torque[/TD]
    [TD]705 Nm at 6,750 rpm[/TD]
    [/TR]
    [TR]
    [TD]Max. engine speed[/TD]
    [TD]8,900 rpm (limiter)[/TD]
    [/TR]
    [/TABLE]
    Dimensions and weight
    [TABLE="class: cms_table_noborder, width: 380"]
    [TR]
    [TD]Length[/TD]
    [TD]4,656 mm[/TD]
    [/TR]
    [TR]
    [TD]Width `[/TD]
    [TD]1,961 mm[/TD]
    [/TR]
    [TR]
    [TD]Height[/TD]
    [TD]1,273 mm[/TD]
    [/TR]
    [TR]
    [TD]Dry weight**[/TD]
    [TD]1,415 kg[/TD]
    [/TR]
    [TR]
    [TD]Weight distribution[/TD]
    [TD]46% front - 54% rear[/TD]
    [/TR]
    [/TABLE]
    Tyres and wheel rims
    [TABLE="class: cms_table_noborder, width: 385"]
    [TR]
    [TD]Front
    Rear[/TD]
    [TD]275/35 ZR 20” 10” J
    315/35 ZR 20” 11.5” J[/TD]
    [/TR]
    [/TABLE]
    Performance
    [TABLE="class: cms_table_noborder, width: 398"]
    [TR]
    [TD]Max. speed
    0-100 km/h
    0-200 km/h
    Fiorano lap time[/TD]
    [TD]in excess of 340 km/h
    2.9 sec
    7.9 sec
    1’21”[/TD]
    [/TR]
    [/TABLE]
    Fuel consumption and CO[SUB]2[/SUB] emissions
    Fuel consumption*** 15.4 l/100 km
    Emissions*** 360 g/km
    * Engine power is expressed in kW, as defined by the International System of Units (SI), and in cv (1KW=1.3596216 cv). With dynamic ram effect
    ** With optional lightweight options
    *** ECE+EUDC with HELE system
    Ferrari
  2. *Brando*
    8.736
    1.253
    10 Settembre 2009
    La trovo splendida! :cool:
  3. Tizy_juiced
    18.396
    420
    29 Aprile 2010
    vabbè io moio.
  4. andreas_ba
    5.073
    358
    28 Dicembre 2010
    VW Lupo
    Sera, :vamp:
    Blu Francia pastello su campione (in omaggio al nome che porta) con tetto in tinta; cerchio (se possibile a 5 razze) silver standard (color cerchio); pinza blu dello stesso colore della carrozzeria con scritta bianca; interno in alcantara nero con cuciture silver misto tessuto tecnico 3D nero con sportelli in tessuto ignifugo antracite con riflessi silver (come sulla 599 GTO). Inserti in carbonio high-gloss, non matto.
  5. davide_qv
    10.223
    674
    16 Aprile 2007
    BMW E91 325I MSPORT
    certo che mi fa di un nervo che la FERRARI presenti RENDERING invece che l'auto vera....
    cmq par fantastica ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  6. giacomo
    13.866
    958
    4 Marzo 2004
    Renault Clio
    l'ultima vera ferrari;
    un motore aspirato di alta cilindrata;
    al bando quelle realizzazioni con la turbinetta...
    "peccato per il superbollo"
    saluti
  7. Roger84
    17.151
    906
    22 Novembre 2004
    A parte il colore, una macchina assolutamente da sogno!!!:sbav:
  8. beckervdo
    4.447
    Un chiaro omaggio alle 275 Tour de France
  9. DerrickNAE3
    10.574
    1.258
    30 Luglio 2013
    Dai, e secondo te chi compra quest' auto si preoccupa del Superbollo?:mrgreen: E quante se ne venderanno in Italia?:-k Comunque stupenda, come dici tu, l' ultima VERA ferrari, bellissima anche in giallo, anche se continuo a preferirla in rosso;), pur essendo una TDF che come scrive l' Ill.mo dott. Andreas:mrgreen:, dovrebbe in teoria essere blu Francia;).
  10. actarus8v
    50.710
    5.224
    no vabbè......vado in bagno :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  11. LupoTHP
    4.608
    1.445
    18 Dicembre 2013
    MX5 ND sport
    Quelle artigliate sui passa ruota posteriori sono da sburro vero!!! :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  12. giacomo
    13.866
    958
    4 Marzo 2004
    Renault Clio
    no, sono io che mi "preoccupo" del superbollo:evil:
    ciao
  13. AlexMi
    25.820
    2.975
    4 Aprile 2004
    Funny Car
    Molto molto bella, del resto la F12 già oggi è la Ferrari più bella in produzione e il motore 12v aspirato da solo vale tutto.
  14. mumm121
    mumm121 Direttore Corse
    1.659
    912
    19 Marzo 2013
    F31 320xd VENDUTA
    La 5 foto in particolare mi lascia basito.Penso, abbiano realizzato uno dei piu' bei musi di sempre.
  15. nivola
    nivola Presidente Onorario BMW Top Reference
    18.745
    11.214
    6 Aprile 2008
    موليز
    Turbo
    Diesel
    F.....ast?!
    :haha :haha
  16. wuli1062
    wuli1062 Direttore Corse
    2.025
    65
    9 Dicembre 2014
    2AT 218D MT Msport 18" Mineral White
    Mamma mia quanto è spettacolare!!!!!!
    Inviato dal mio ASUS Tablet P1801-T utilizzando Tapatalk
