[Tutorial] Menu segreto BC su E46
Discussione in 'BMW Fai da te e tutorial: trucchi e consigli' iniziata da resunoiz, 12 Settembre 2006.
  1. resunoiz
    14.887
    356
    26 Dicembre 2004
    scusate, ma nn ritrovo più la procedura e le funzioni x il menu segreto del BC E46..volevo vedere la vel effettiva e valutare lo "scarto" (autovelox rulez:cool: ) , inoltre vedere la temp olio...potete ripostarmelo o darmi il link del post? azzzieeee:redface: 8-[
  2. Bolletta
    10.422
    490
    26 Aprile 2006
    Vari rottami bavaresi®
    Instructions to access the hidden OBC functions:
    1. Hold Trip Reset while turning ignition key to On position
    2. OBC should show "Test"
    3. Use Trip Reset to select function 19.0 that unlocks all the
    features
    3. Wait for display to show "Off"
    4. Depress Trip Reset for 1/2 second and release it
    5. With no delay press Trip Reset several times to select one of the
    following function s
    BMW E46 On-Board Computer (OBC) Hidden Codes
    nr example description
    1 Car Engine and cluster data
    1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
    1.1 4nnn K-number
    1.2 690236 Cluster Part #
    1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
    1.4 1200 Week (12)/year of manufacture (2000)
    1.5 09_160 Hardware (09) and software # (16.0) of cluster
    1.6 Not used
    1.7 04__44 CAN-version (04) KI-revision index (44)
    2 (test) Cluster System Test - Acticates the gauge drivers,
    indicators and LEDs to confirm function
    3 SI Data
    3.0 1098 Used fuel in litres since last SI (Service Inspection)
    3.1 0231 Periodic inspection days; elapsed days (since last SI)
    4 Momentary Consumption
    4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
    4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
    5 Distance Gone Consumption
    5.0 082 Average mileage; 082=8.2 liters/100km
    5.1 0536 Calc. km to refuel (momentary distance to go)
    6 Fuel Level sensor inputs in liters
    6.0 109330+ Fuel level averaged; Left half sensor input=10.9
    liters; Right sensor input=33.0 liters
    6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9
    liters
    6.2 0442+ Indicated value (44.2) and tank phase
    7 Temperature and Speed
    7.0 021+ Coolent/Engine temperature (2.1C) koelvloeistof-temp.
    7.1 130 Ambient/Outside temperature - chg met 5 pts.
    125/130/135
    7.2 + Engine speed / Current RPMs 1/min
    7.3 + Vehicle speed / Current Speed in km/hour
    8 Input value in HEX form
    8.0 1d0+ System voltage ADC-Value Hex code
    8.1 26C33C+ ADC Values HG left/HG right
    8.2 0000 ADC Value brake degradation sensor (000=o.k.)
    8.3 18C ADC Value outside temperature
    9 Battery
    9.0 140 Battery Voltage - 140 = UB 14.0v
    9.1 242013+ ?
    9.2 074_78+ ?
    9.3 0011+ ?
    10 Not used
    11 Not used
    12 Not used
    13 GonG Gong Test
    14 Not used
    15 Status cluster I/O-ports (bit codes) 0=low; 1=high
    1st-belt contact, seat belt fastened=0; 2) ignition
    lock contact, key inserted=0; 3) door contact, door open=0; 4) clock
    button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission
    failure=0
    Status Digital Outputs (bits) 0=inactive, 1=active
    1) Gong output; 2) Brake warning lamp; 3) Low fuel
    warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
    16 Not used
    17 Not used
    18 Not used
    19 Lock Status; unlocks functions in range 3-18
    19.0 L-On/L-Off Unlock: press button when "L-Off"
    20 Not used
    21 Software Reset; reset OBC settings
    00 End of test
    CAAAAAAALMI... adesso vi spiego cosa significa questo post...
    ogni e46 (e anche altre serie5) hanno nel computer di bordo un programma di diagnostica che serve ai tecnici bmw per valutare eventuali problemi.....
    ma ci sono anche delle cose molto fighe che nessuno vi dira' mai in concessionaria....
    come i giri/minuto digitali (precisissimi) velocita' digitale (anche questa precisa al millimetro)
    massime e minime temperature raggiunte dal motore
    quantita' di benzina usata fino ad adesso....
    etc etc... (adesso le altre le le traducete voi.....)
    come si accede al sistema:
    1)tenere premuto il pulsante per l'azzeramento dei km mentre si gira la chiave in posizione "acceso" (pos 2)
    2)OBC mostrera la scritta test
    3) sempre con il pulsante azzera-km scorrete le varie funzioni fino alla 19.0 (che serve a sbloccare il menu'.. dato che solo 2-3 possono essere usate senza l'attivazione)....
    4)aspettate che il display mostri OFF_
    5) premete il pulsantino per mezzo secondo e quindi rilasciatelo (okkio ad essere precisi altrimenti non funzia.. a me ci sono voluti 3 tentativi)
    6) scorrete senza soffermarvi troppo le varie funzioni (se vi fermate troppo su un numero lo attivate quello che c'e')....
    adesso spieghiamo i codici:
    quasi ogni numero ha una specie di sottomenu' con differenti funzioni
    1 - codici motore e dati della macchina (telaio,numero seriale del modello, data di produzione)
    2 - test di tutte le spie e di tutte le lancette (questo e' figo e funzione anche senza attivare il 19.0)
    etc etc...
    arrivati alla 7.2 (che sono i giri al minuto) e alla 7.3 (che e' la velocita' istantanea9 potete rendervi conto di quanto "ruba" il vostro contagiri e il vostro tachimetro
    9 - reparto batteria (voltaggio e co.)
    ATTENZIONE!!!!!
    arrivati alla funzione nr. 21.0 (guardate di saltarla sempre) evitate di toccare tutto.....
    il 21.0 E' IL RESET DI TUTTO L'OBC vi ritrovereste senza dati e senza cruscotto.. poi andateci voi in conce a spiegargli che stavate cazzeggiando.. e avete sbagliato)
    ultimo consiglio... non cercate di attivare la velocita o i giri/min. digitali quando guidate... e' pericoloso.... non tanto per il Software ... quanto per voi che rischiereste di fare dei danni!!!!
    A Peloponnesiaco, Grazbazz, alexandrosroma e ad altre 3 persone piace questo elemento.
  3. resunoiz
    14.887
    356
    26 Dicembre 2004
    grande bollettazzo!!!! ora lo metto come "memo" importante, cosirimane ad inizio pag! :wink:
  4. Bolletta
    10.422
    490
    26 Aprile 2006
    You're welcome:wink:
    era un copia-incolla che avevo fatto qualche tempo fa.
    Ovviamente "all rights reserved" di chi l'aveva scritto originalmente (Davide? Riddle? Fr4ank? boh! :mrgreen: )
  5. Pero155
    Pero155 Direttore Corse
    2.067
    59
    23 Agosto 2006
    320d e46 touring M-tech resty
    lo sai bolletta che non mi hai fatto venire punta voglia di provare....!!!
  6. Bolletta
    10.422
    490
    26 Aprile 2006
    eheheh, immagino! :wink:
    quando vieni quassù in capitale? :cool:
  7. Pero155
    2.067
    59
    23 Agosto 2006
    appena mi riesce senti quell'idiota!!!non risp mai!ma te lo conosci bene quante me???quando vengo mi fai vedere come funziona sto menù segreto vai!Però prima sulla tua è!!!
  8. fr4nk
    fr4nk Collaudatore
    410
    19 Aprile 2006
    320d e46 restyling
    ...se non ricordo male nessun menù visualizza la temperatura dell'olio...
  9. resunoiz
    14.887
    356
    26 Dicembre 2004
    una curiosita: questo va fatto con la chiave in posiz "2", no?
    ok, setto che volgio vedere ad es. la velocità istantanea in digitale; poi metto in moto direttamente dalla posiz 2, se rimando indietro la chiave si riazzera tutto e tornano le normali funz del BC..giusto?
  10. Etna
    Etna Amministratore Delegato BMW
    3.904
    253
    10 Gennaio 2006
    320d E46 Attiva
    Giusto!!! :wink:
  11. resunoiz
    14.887
    356
    26 Dicembre 2004
    adesso mi ricordo perchè nn l'ho mai usato..io nn arrivo alla funz 19 x sbloccare, arrivato a 10 torna a zero.... :sad:
  12. giorambo
    giorambo Direttore Corse
    2.469
    26
    26 Marzo 2005
    535D Msport 378cv -330D 270 cv
    perché devi essere veloce!cioé:appena ti compare test devi subito premere il pulsante azzera km e comincerai a scorrere i numeri fino al 19 e devi essere veloce e non tenere premuto poi appena arrivi a 19 e vedi la scritta che si alterna con ON/OFF aspetta di vedere OFF e clicca velocemente 2 volte e comincia a scorrere tutte le funzioni ma fallo velocemente altrimenti attivi la funzione dalla quale stai passando le uniche che puoi scorrere con calma e mentre stai camminando sono le sottofunzioni(es.7,1 7,3 9,2....)ma per passare da 7 a 9 ad es devi spegnere il quadro e rifare tutto :wink:
    spero di essere stato chiaro,se aveste qualche dubbio ditelo:razz:
  13. resunoiz
    14.887
    356
    26 Dicembre 2004
    nn è un probl di velocita..arriva a 10 e poi di nuovo zero..
  14. giorambo
    2.469
    26
    26 Marzo 2005
    e quindi vedi scorrere i numeri 1 2 3 4 5 6 7 fino al 10?cioé vedi solo quelli oppure 1,2 1,3 1,4 1,5....?:-k
    mi sembra lo stesso errore che feci io all'inizio...quando premi il tasto azzera km e poi giri il quadro e ti appare la scritta test devi rilasciare subito il tasto e ripremerlo in meno di mezzo secondo... tu hai fatto cosi?
  15. giorambo
    2.469
    26
    26 Marzo 2005
    ma é possibile vedere dal menu segreto i km reali dell'auto?si puo attivare o disattivare la chisura porte in automatico?:-k
  16. RALLYMAN
    15.797
    170
    11 Febbraio 2004
    335xi E90 M-Sport+530d Futura
    No, x quello devi andare in conce.
  17. giorambo
    2.469
    26
    26 Marzo 2005
    :wink: grazie!
  18. iamback
    iamback Primo Pilota
    1.399
    33
    23 Ottobre 2006
    Milano
    BMW i3 120Ah
    Io non riesco ad accedere al menu..o meglio accedo ma non arrivo alla 19. Faccio 1.1 1.2 1.3 fino a 1.7 e poi ricomincia....ho provato ad essere + veloce ma forse non ho ben capito.....a qualcuno è successo o mi spiegate come devo essere + veloce?
  19. BMWJZ
    BMWJZ Amministratore Delegato BMW
    3.446
    99
    19 Dicembre 2006
    E280 177HP VS 320d 150HP
    non penso serve solo per visualizare i dati dell'auto secondo quello ke ho letto nei siti diversi
  20. BMWJZ
    3.446
    99
    19 Dicembre 2006
    dovresti tenerlo schiacciato qualke secondo ma solo se l'hai sbloccato
