Trucchi OBC X5 (05)
Discussione in 'BMW X5 E53' iniziata da sovrasterzo85, 2 Aprile 2006.
  1. sovrasterzo85
    sovrasterzo85 Direttore Corse
    2.270
    21
    2 Aprile 2006
    una di quelle a 4 ruote
    ...qualcuno gentilmente saprebbe indicarmi dove si possono trovare i trucchi per il computer di bordo dell x5 restyling?? grazie mille
  2. pelvix
    pelvix Collaudatore
    479
    22 Febbraio 2006
    Scusa, ma di che trucchi parli?
  3. sovrasterzo85
    2.270
    21
    2 Aprile 2006
    ...parlo delle funzioni che ha il computer di bordo a cui noi nn abbiamo accesso...io ho quelli dell E46 ma nn so se sono uguali anche per l X5
  4. Nik-Mo
    Nik-Mo Aspirante Pilota
    38
    6 Dicembre 2005
    PER ACCEDERE AL MENU' SEGRETO:
    E' CARINO, TI DA LA VELOCITà EFFETTIVA, LA TEMP REALE DELL'ACQUA, LA TENSIONE BATTERIA ETC
    The Check Control in the instrument cluster of the current BMW 5/7series hides somes secrets. Here is the procedure how to unveil them and how to unlock the system to get access to all tests:
    Turn ignition to pos. II
    Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
    Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
    Push the right button until you see "Test Nr.19"
    Push left button until you see the number that is equal to the one you calculated above
    Push right button again
    Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON
    Most of the tests are self-explaintory, and here is a first listing (as far as I can recall):
    1. Display Car's identification number, HW/SW version, date of construction
    2. A very beautiful instrument test
    2. Current consumption (liters/100 km)
    3. Current consumption (liters/hour)
    4. Average consumption (liters/100 km)
    5.Current range
    6. N/A
    7. Average fuel in tank (liters)
    8. Current Speed (kph)
    9. System voltage at Term. "R" (Battery Voltage)
    10.Country/Language (US, Spa, Ger, Jap, etc.)
    11. Units am/pm
    12. Average Speed
    13. ETA
    14. Date of Software Mask
    15. Production Diagnosis
    16. ""
    17. Display Vehicle Specific Data
    18. Alarm Changeover (cont. vs. intermittent OBC chime)
    19. Lock/Unlock
    20. Correction factor for fuel consumption (nicht ändern!)
    21. Reset all defect codes
    1. several numbers and data
    2. [Dispay Test]
    3. VBR: x,x (liters/hr)
    4. RW-VBR: x,x (liters/100 km)
    5. RW: x (km)
    6. N/A 7. TMTL: x,x (liters)
    8. V: x (kph)
    9. UB: xx,xx (V)
    10. LAND: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB
    11. EINHEIT 1: B3, B4, B5, B6, B7, B8, B9, BA, BB, BC, BD, BE, BF, B0, B1
    EINHEIT 2: [similar to above, I didn't want to mess with it]
    12. VANK: xx,x (kph)
    13. ANK:xx:xx
    14. ROM:
    15. DIAG: 01 01 000 E3
    16. PORT: 01 101010000, 02 101010000, 03...etc
    17. PROM: 00 12, 01 37, 02 18, 03 E6, 04 02, 05 B3, 06 FF, 07 7E
    18. HORN: DTON or [DTON flashing]
    19. LOCK: ON
    20. KVBR: 1000
    21. RESET?
    5.Current range
    6. N/A
    11. Units am/pm
    12. Average Speed
    13. ETA
    16. ""
    19. Lock/Unlock
    2. [Dispay Test]
    5. RW: x (km)
    8. V: x (kph)
    9. UB: xx,xx (V)
    13. ANK:xx:xx
    14. ROM:
    19. LOCK: ON
    20. KVBR: 1000
    21. RESET?
    :lol:PER ACCEDERE AL MENU' SEGRETO:
    5.Current range
    6. N/A
    11. Units am/pm
    12. Average Speed
    13. ETA
    16. ""
    19. Lock/Unlock
    2. [Dispay Test]
    5. RW: x (km)
    8. V: x (kph)
    9. UB: xx,xx (V)
    13. ANK:xx:xx
    14. ROM:
    19. LOCK: ON
    20. KVBR: 1000
    21. RESET?
    :lol:
    Passa alla modifica normale
  5. cristianov2004
    cristianov2004 Kartista
    71
    17 Aprile 2006
    menu segreto
    per quanto riguarda la x5 esiste un sito americano x5world.com si trovano delle cose veramente interessanti . Trovi anche i software per gli aggiornameti dei navigatori . Ciao
