Nokia E65..
Discussione in 'Cellulari e telefonia' iniziata da guddrum, 29 Febbraio 2008.
  1. guddrum
    3.818
    169
    18 Settembre 2006
    In azienda siamo da poco passati a 3.. ci hanno dato i cellulari e li stavo testando con un'altra sim...
  2. goblin
    goblin Presidente Onorario BMW
    8.184
    133
    5 Novembre 2003
    520d F11
    Ok, sbrandizzazione da scartare allora! :D
    Cmq se lo usi con una sim 3 non ci dovrebbero essere problemi :wink:
  3. guddrum
    3.818
    169
    18 Settembre 2006
    Allora, credo di aver capito qualcosa... praticamente sul sito della Parrot ho trovato le distruzioni... ma sono in inglese...
    Nokia 810 Contact Download Application User guide​
    To make it compatible and get your phonebook into the carkit, you need to install a
    third party software on this phone: 'Nokia 810 Contact Download' application.
    How to install this software on your phone ?
    You need to install it on your phone with a PC with Bluetooth connectivity (such as a
    Bluetooth Dongle).
    Please follow these steps :
    1. Please pair your phone to the car kit and switch off your engine.
    2. Launch the bluetooth manager that is provided with the Bluetooth Dongle's software.
    3. Find all the bluetooth devices and select your phone.
    4. Use the OBEX FILE TRANSFER feature of your phone.
    5. Define a Bluetooth PIN code.
    6. A window will appear on your phone, enter the same bluetooth PIN code.
    7. Send The software you have downloaded to your phone. Don't forget to accept the file
    transfer on your phone.
    8. You will receive a message on your phone. Open it and follow the instructions. Wait
    until the download is finished.
    9. If the installation is successful you should find an icon with a car and a computer.
    Once you have installed the specific software on your phone :
    1. Please make sure your phone is paired to the car kit.
    2. Switch off your car kit.
    3. On your phone go to the MENU screen.
    4. Select the software you have installed : the icon with a car and a computer.
    5. Select the OPTIONS command.
    6. Select OPEN command.
    7. Select the OPTIONS command again.
    8. Select OPEN command.
    9. Then switch on your engine.
    10. Wait until the car kit tell you the end of the synchronization.
    You can now assign voice tags. Refer to the voice commands menu.
    Praticamente mi pare che la cosa sia fattibile, ma ci sono dei punti che non mi sono chiari...​
  4. guddrum
    3.818
    169
    18 Settembre 2006
    Mi sono mangiato il fegato ma alla fine ce l'ho fatta!!!
  5. goblin
    8.184
    133
    5 Novembre 2003
    520d F11
    Ottimo! :wink:
    Hai seguito la procedura che hai messo sopra?
  6. guddrum
    3.818
    169
    18 Settembre 2006
    si, ho scaricato l'applicazione e l'ho installata nel telefono e parrot...
    tral'altro (davvero una figata!!!) adesso quando mi chiamano sento la sigla di supercar, e quando mi arriva un messaggio sento (in vivavoce) il tono messaggio BMW...:mrgreen:
  7. goblin
    8.184
    133
    5 Novembre 2003
    520d F11
    Se hai il tomtom sul cell quando ti vengono date le informazioni vocali viene attivato il mute dell'autoradio e le senti dalle casse dell'auto... una figata! :D
  8. guddrum
    3.818
    169
    18 Settembre 2006
    NO, quello non ce l'ho... ho già il navi di serie...
    Grazie per il prezioso aiuto... rep +..
