moduli per le nostre BMW
Discussione in 'Forum generale BMW' iniziata da sharkrunner, 3 Maggio 2004.
  1. sharkrunner
    sharkrunner Amministratore Delegato BMW
    3.925
    22
    20 Aprile 2004
    R8 V10 e M3 V8
    dal sito: http://www.carpassionata.com/german/shop/index.php
    è possibile acquistare interessanti "centraline" per le nostre bmw...
    che ne dite di un acquisto collettivo?
    Così da spuntare qualche sconto particolare....
    io prenderei:
    eOpen
    eOpen Drive
    eMax
    ciao :cool:
  2. aristoweb
    aristoweb Presidente Onorario BMW
    7.393
    19 Luglio 2003
    BMW M3 Coupé E92
    Ma centraline de ke?
  3. sharkrunner
    3.925
    22
    20 Aprile 2004
    R8 V10 e M3 V8
    eLight standard
    you determine the order of lighting
    By closing the vehicle with your remote key, only the turnsignals light up for
    acknowledgement.
    With eLight you configure the sequence of the complete lighting system.
    Delivered with software, data cable and instructions.
    The module can be installed into the BMW types of BMW3 E46, BMW5 E39, BMW7
    E38, X5 E53, Z4 E83 and X3 E83.
    eLight deluxe
    with comfort turn signal
    Function range as eLight standard. However extended of the function comfort turn signal,
    1 x tapping = 3 x flashing. A comfortable solution for many drivers.
    The function comfort-flashing can alternatively be activated or deactivated.
    Delivery with software, cable and instructions.
    The module can be installed into the BMW types of BMW3 E46, BMW5 E39, BMW7 E38, X5
    E53, Z4 E83 X3 E83 and Rover 75 R40.
    eLight comfort
    home light and comfort turn signal comfort
    Function range as eLight deluxe. However with sensor-steered home light.
    Due to time-delayed switching off of your high beams a safe way home is made possible.
    Delivered with software, cable and instructions.
    X5 E53, Z4 E83 X3 E83 and Rover 75 R40.
    eLight professional
    with open CLOSE function
    Module as eLight comfort plus:
    Locking the vehicle by starting and unlocking during "starter lock position 0".
    The functions comfort-flashing, way-finder, locking and unlocking can be individually
    switched on and off by the programming software.
    Z4 E83, X3 E83 and X5 E53 without Facelift.
    eLight special X
    with deactivation of acoustic belt warning
    As eLight professional plus:
    Deactivation of the acoustic belt warning.
    The functions comfort-flashing, WayFinder, locking and unlocking and belt warning can be
    individually switched on and off by the programming software.
    The module can be installed into the BMW type of X5 E53 with Facelift.
    eTip OpenClose
    CLOSE > comfort turn signals with open CLOSE
    1 x typing = 3 x flashing. Ideal for the ride on the motorway. Additional
    function: Locking the vehicle by starting and unlocking during "starter lock position 0".
    The module is to be operated without software and connected with only 3 (!) cables to the
    vehicle.
    eTip OpenClose for X5
    deactivation of the belt warning
    !! Delivery currently not possible !!
    1 x typing = 3 x flashing. Ideal for the driving on the motorway. Additional
    Deactivation of the akkustischen Gurtwarners
    vehicle.
    The module can be installed into BMW X5 with Facelift.
    eTelevision
    watching television while driving
    Offer alternation during longer travels to your passengers. eTelevision is
    simple and fast installed. This module is a car solution development.
    Motor vehicle type: All cars with TV function 4:3 or 16:9. Exception: E65.
    eConnect
    attaching DVD and Mp3 to the Car TV
    With this AV-cable you are able to connect external appliances such as DVD or Mp3-Player to
    your car TV.
    Ideal in combination with eTelevision.
    eOpen
    electronic locking and unlocking by remote key
    Open and close your convertible comfortably with the standard radio key.
    With the extension < drive > even up to a speed of 25/kmh.
    Car type : BMW E46 and BMW Z4
    eOpen drive
    open/close convertible top at 25 km/h
    Never standing in the rain again. With the solution eOpen drive you are able to open and
    close the electronic convertible top uo to a speed of 25 km/h.
    When it starts to rain you don`t have to go looking for a bridge anymore to keep the car
    interior dry.
    Protect the interior against wetness. The module works independently from the eOpen
    module!
    eControl
    extension of the multifuntional steering-wheel with 8 functions
    With eControl you can occupy the keys of the multifunctional steering wheel
    to 8 additional functions. Software with easy serving functions is for disposal. Open your
    mind – it´s a nice tool.
    eMax
    Vmax eliminaton without mechanical intervention
    The elegant solution: eMax permits a Vmax elimination of your vehicle without intervention
    in to the car mechanic.
    The installation is very simple and is to be accomplished by yourself.
    Importantly: Mount tires for speed over 250 km/h!
    eJack
    lifting and lowering the vehicle by keys
    eJack makes it possible to lift and dip your vehicle for a total distance of approx. 70-80mm.
    This works by pressing the buttons on your multifunctional steering-wheel.
    total distance of approx. 70-80mm or lowered.
    The module works without mechanical changes in the vehicle!
    Precondition: BMW 5 / X5 with inserted niveau level control.
    eShift
    shifting at the steering wheel
    Comfortable and safe shifting of the automatic transmission by keys at the multi-functional
    steering wheel.
    A multifunctional steering-wheel can be readapt, it not present.
    eSound
    Stereosound for DVD and Mp3-Player
    With eSound it becomes possible to listen to DVD or Mp3-Player in stereo.
