Model Year 2012
Discussione in 'BMW X3 F25' iniziata da X3 bianca, 16 Febbraio 2012.
  1. X3 bianca
    X3 bianca Aspirante Pilota
    24
    22 Gennaio 2012
    X3 F25 Futura M-Sport
    L'ho ritirata neanche un mese fa ed ecco annunciate le novità del model year 2012 che verranno commercializzate da primavera. Non mi interessa tanto il motore a benzina, quanto le altre cose...
    New BMW X3 xDrive28i: Faster sprint, better fuel economy thanks to BMW TwinPower Turbo Technology.
    Starting in the spring of 2012, all BMW X3 model variants will be powered by engines equipped with BMW TwinPower Turbo Technology. The latest addition to the drive train portfolio is the 2-litre, four-cylinder 180 kW/245 hp petrol engine, which gives the BMW X3 xDrive28i even more power and efficiency. The technology package employed in this engine comprises a supercharging system operating according to the Twin Scroll principle, High Precision Injection with direct fuel injection, VALVETRONIC variable valve control and double VANOS variable camshaft control. This combination guarantees not only spontaneous throttle response and sporty power delivery continuing into the high load range, but also fuel economy that is outstandingly favourable even for a petrol engine of this performance class.
    Compared to the predecessor engine, the new power unit mobilises 40 percent higher maximum torque, which has now increased to 350 Nm and is available within a significantly broader engine speed range between 1,250 and 4,800 rpm. Thanks to the boost in pulling power and response resulting from this, the new BMW X3 xDrive28i accelerates from 0 to 100 km/h in just 6.7 seconds – 0.2 seconds faster than the predecessor model. The advancement made in terms of efficiency is even more significant. With an average fuel consumption of 7.5 litres/100 km in the EU test cycle and a CO2 emission level of 175 grams per kilometre, previous figures have been undercut by around 17 percent.
    The new power unit comes as standard in conjunction with the eight-speed automatic transmission. The intelligent four-wheel drive system BMW xDrive with electronically controlled and variable power distribution between the front and real wheels provides optimum transfer of torque to the road and off-road terrain.
    Driving Experience Control including ECO PRO Mode as standard.
    Moreover, in future, all BMW X3 model variants will be equipped as standard with the Driving Experience Control feature. At the press of a button located on the centre console next to the gearshift lever or gear selector lever respectively, the driver is able to vary the vehicle setting. There is a choice between the “COMFORT”, “SPORT” and “SPORT+” modes as well as the ECO PRO mode. Driving Experience Control has an effect on the settings of the stability control function DSC, the characteristic maps of the accelerator pedal and Servotronic power steering and, depending on how the vehicle is equipped, also the gearshift characteristics of the automatic transmission and the control map of the Dynamic Damper Control system.
    In the ECO PRO mode, an exceptionally economical driving style is supported thanks to corresponding adjustment of the drive control and efficiency-optimised operation of the heating and air-conditioning unit, the exterior mirror heater and the seat heater. Specific visual displays in the instrument cluster inform the driver about the additional range obtained as a result.
    Extended range of BMW ConnectedDrive features.
    In the spring of 2012, the choice of BMW ConnectedDrive driver assistance systems available for the BMW X3 is also to be extended yet again. The Speed Limit Info System including the No Overtaking Display is now available as a new option. The system informs the driver by means of corresponding symbols in the instrument cluster about identified speed limits and no overtaking signs at the roadside or on overhead sign gantries identified by its camera.
    In addition, the BMW X3 is now also available with the Lane Departure Warning function including Collision Warning. This system monitors road markings by means of a camera mounted on the base of the rear view mirror and helps to avoid unintentional course deviations. If the vehicle leaves the lane before the direction indicator has been activated, the steering wheel begins to vibrate. In addition, the camera detects other vehicles ahead and, if necessary, a two-stage alarm function comprising visual and acoustic signals is activated to avoid collisions.
  2. RodrigoDdV
    RodrigoDdV Aspirante Pilota
    12 Febbraio 2012
    X3
    Pensa te! Io l'ho ritirata meno de due settimane fa... :-(
  3. X3 bianca
    24
    22 Gennaio 2012
    Su internet si trovano vari articoli (in italiano) con le novità annunciate dalla casa madre ma ancora non c''e scritto da quando saranno commercializzate. si parla solo genericamente di primavera...
  4. pastura
    pastura Direttore Corse
    1.839
    18
    13 Settembre 2009
    X3 F25 xDrive20d
    Diciamo che le prime si vedranno nel 2013, si sono finalmente accorti che dovevano mettere qualche cosa in più per essere competitivi con le Jap...
    Un po mi giran le scatole anche se la mia l'ho presa lo scorso anno, vediamo comunque di quanto alzeranno il listino dopo aver incluso questi optional...
  5. Alligator
    Alligator Primo Pilota
    1.398
    110
    29 Dicembre 2008
    X1 U11 30e - Mini Countryman SE
    Le funzionalità del Navi secondo me saranno codificabili... già vedo Smerki e affini al lavoro ... :wink:
  6. Spada72
    Spada72 Kartista
    72
    24 Gennaio 2012
    X3 F25 2.0d Futura
  7. nicolasvan
    nicolasvan Primo Pilota
    1.394
    18 Maggio 2007
    X5
    l' annunicio parla di primavera 2012
  8. fesorice
    fesorice Direttore Corse
    1.798
    206
    18 Giugno 2007
    Roma
    X6 30dM X5 30dM
    Finchè sono cambiamenti di allestimento e di funzionalità software...il problema sarebbe se ci fossero modifiche estetiche o agli interni!! Ogni anno bmw fa uscire un MY per i propri modelli...ma non ha mai stravolto le sue vetture come invece fanno molti altri marchi!
  9. ilcarlo
    ilcarlo Kartista
    156
    16 Febbraio 2007
    BMW 320d E90 Futura
    Lunedì sono andato a farmi fare un preventivo per una X3 futura, consegna prevista per fine aprile primi maggio e sul preventivo c'è scritto "bmw x3 xdrive 20d futura model 2012"
    il venditore mi ha detto che ci saranno modifiche nel multimedia, sw, navigatore e piccole cose e la soluzione a piccoli problemi nativi...
    Se decido per l'acquisto (dato dal fatto che mi hanno trattato veramente bene, come sconto e valutazione usato) staremo a vedere.
  10. Spada72
    Spada72 Kartista
    72
    24 Gennaio 2012
    X3 F25 2.0d Futura
    Chissà che queste micromodifiche sul MY2012 (se esiste), non mi ripaghino dell'estenuante attesa...consegna prevista 31/5.
  11. pastura
    1.839
    18
    13 Settembre 2009
    X3 F25 xDrive20d
    Il MY2012 esiste, ma dubito che tali modifiche siano montate sulla tua X3 in arrivo, a meno che anche sul tuo contratto non ci sia scritto MY2012
  12. Spada72
    Spada72 Kartista
    72
    24 Gennaio 2012
    X3 F25 2.0d Futura
    Grazie della precisazione Pastura. Trattandosi di un NLT ho visto solo l'ordine inoltrato a metà ottobre (!) dalla mia società ma non non ho mai visto il contratto. Vista l'incredibile attesa (a maggio saranno 8 mesi!) temo la vettura sia stata ordinata ben più tardi di metà ottobre. Boh...
  13. pastura
    1.839
    18
    13 Settembre 2009
    X3 F25 xDrive20d
    Spero per te che sia già il MY2012 anche se sono scettico, anche perché i servizi di NLT spesso trattano con macchine semestrali a km0...
  14. Alexiena
    Alexiena Aspirante Pilota
    5 Febbraio 2012
    Bmw X3 (F25) 2.0D Futura
    Ciao, io sto aspettando che arrivi la mia ( è nel bel mezzo dell'oceano ora...) e l'arrivo è previsto per la 14a settimana 2012. Sul contratto c'è solo il modello ma non c'è traccia di alcun "MY2012"; il conce quando ho fatto l'acquisto ( 31/01/2012) mi ha detto che tutte le vetture ordinate post 1 gennaio sono MY2012.
    Appena ho un secondo lo chiamo e approfondisco l'argomento per avere la conferma...
    Alex
  15. Spada72
    Spada72 Kartista
    72
    24 Gennaio 2012
    X3 F25 2.0d Futura
    Non saprei, in passato con Alphabet mai avuto problemi ma forse perchè giocavano in casa...Si trattava di vetture con tempi di attesa più ragionevoli ma in 10 settimane le ho ritirate (per la precesione 120d attiva e 320d coupè attiva). Vedremo il libretto.
  16. X3 bianca
    24
    22 Gennaio 2012
    Il model year 2012 va in listino dall'1aprile.
    Queste le novita': Nuovo motore TwinPower Turbo per X3 xDrive28i WX91 (sostituisce precedente WX51)
    Eco PRO e pulsante selettore del feeling di guida di serie per tutti i motori
    Introduzione nuovi optional: 8TH Speed limit info (330 euro); 5AD Avvisatore di cambio accidentale di corsia di marcia (LDW) e di rischio tamponamento (530 euro); 3MC Barre portatutto BMW Individual black high-gloss Shadow Line (710 euro)
  17. pastura
    1.839
    18
    13 Settembre 2009
    X3 F25 xDrive20d
    Mettono il bottoncino del feeling di guida e non la radio business per tutti i modelli?
    Sulla nuova serie 3 ci sono entrambe se non erro...
  18. Alexiena
    5 Febbraio 2012
    .. piu' che altro mi piaceva l'idea di avere la funzione Eco pro, e parlando il conce mi diceva che dovrebbe esserci; comunque fra poco arriva e vedremo, speriamo in un lieto fine.....
  19. X3 bianca
    24
    22 Gennaio 2012
    Anche a me sarebbe piaciuta la funzione eco pro... ma l'ho ritirata dalla concessionaria ad inizio febbraio e questa funzione non c'e'. La mia e' stata prodotta nel novembre 2011, arrivata in Italia nella 52/ma settimana e consegnata a inizio febbraio
    Tienici informati...
    Ultima modifica di un moderatore: 22 Febbraio 2012
  20. Alexiena
    5 Febbraio 2012
    Ok, vediamo se quelle prodotte nel 2012 sono aggiornate...tanto se tutto procede nei tempi previsti non manca molto.
    Ora sta' attraversando la manica e per venerdi sara' a bremerheven...
    A presto
    P.s : ma la tua com'e configurata? ( mi sa che si somigliano, o no?)
