A questo punto documentandomi bene sembra che il mio stesso problema sia piuttosto frequente. Attenzione agli aggio Hello, I have the same problem, how can it be repaired ? it seems that the flash memory is gone empty! the unit takes the CD, but does not boot or upgrade or ejects (my after many tries). The red LED lamp is off. Is it possible to re-flash the MKIII units ? Thanks in advance! George --- In bmwnav@yahoogroups.com, Electric TVNet wrote: > Hello, > > This is a few days old thread: Oeps.......upgrading moved to disaster?? > > This only happened whe you disconnect the batery between 55-57sec > after ignition off. This is a known bug. The official solution is a > new unit, but the old one can be repaired. First of all try to > upgrade or downgrade the unit. Is the CD drive working? Can you eject > the CD? > > Bye, > Gaga > > g> Please I need some help... > g> Due to a battery problem, my Mk3 navi is dead. I know that if I > g> disconnect the battery in a short period after turn the ignition OFF > g> this problem can occurs... > g> Is it possible to repair? Flash? Update? Reset?...
Scusate la mia ignoranza a riguardo, ma che problema avete? Se non avete voglia di spiegare magari datemi un link
