ciao ragazzi ho visto in alcune foto che e possibile fare apparire indicazioni diverse da quelle standard sui display del cruscotto. come faccio?
Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to On position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/2 second and release it 5. With no delay press Trip Reset several times to select one of the following function s BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Acticates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in litres since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolent/Engine temperature (2.1C) koelvloeistof-temp. 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+ ? 9.2 074_78+ ? 9.3 0011+ ? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test ogni e46 (e anche altre serie5) hanno nel computer di bordo un programma di diagnostica che serve ai tecnici bmw per valutare eventuali problemi..... ma ci sono anche delle altre cose come i giri/minuto digitali (precisissimi) velocita' digitale (anche questa precisa al millimetro) massime e minime temperature raggiunte dal motore quantita' di benzina usata fino ad adesso.... come si accede al sistema: 1)tenere premuto il pulsante per l'azzeramento dei km mentre si gira la chiave in posizione "acceso" (pos 2) 2)OBC mostrera la scritta test 3) sempre con il pulsante azzera-km scorrete le varie funzioni fino alla 19.0 (che serve a sbloccare il menu'.. dato che solo 2-3 possono essere usate senza l'attivazione).... 4)aspettate che il display mostri OFF_ 5) premete il pulsantino per mezzo secondo e quindi rilasciatelo (okkio ad essere precisi altrimenti non funzia.. a me ci sono voluti 3 tentativi) 6) scorrete senza soffermarvi troppo le varie funzioni (se vi fermate troppo su un numero lo attivate quello che c'e').... adesso spieghiamo i codici: quasi ogni numero ha una specie di sottomenu' con differenti funzioni 1 - codici motore e dati della macchina (telaio,numero seriale del modello, data di produzione) 2 - test di tutte le spie e di tutte le lancette (questo è troppo bello e funzione anche senza attivare il 19.0) etc etc... arrivati alla 7.2 (che sono i giri al minuto) e alla 7.3 (che è la velocita' istantanea) potete rendervi conto di quanto "ruba" il vostro contagiri e il vostro tachimetro 9 - reparto batteria (voltaggio e co.) ATTENZIONE!!!!! arrivati alla funzione nr. 21.0 (guardate di saltarla sempre) evitate di toccare tutto..... il 21.0 E' IL RESET DI TUTTO L'OBC vi ritrovereste senza dati e senza cruscotto... ultimo consiglio... non cercate di attivare la velocita o i giri/min. digitali quando guidate... e' pericoloso.... non tanto per il Software ... quanto per voi che rischiereste di fare dei danni!!!! Ciao! fr4nk
Onde evitare di fare qualche casino, potreste chiarirmi un paio di cosette?!? Queste modalita' valgono anche per l'X3? Al punto 4) per aspettare che compaia "OFF", il pulsante azzera-km va mantenuto premuto o no? Al punto 6) cosa vuol dire "attivate quello che ce'"? Che visualizzo quella funzione? e se succede come faccio per passare ad un'altra funzione? Quando si e' arrivati sulla funzione desiderata, che procedura occorre fare per uscire completamente?!? Oppure una volta tolta l'alimentazione si resetta in automatico? E se agisco con il tastino del trip computer cosa succede? Gia' che ci sono, qualcuno sa se e' possibile sostituire o aggiungere il consumo medio del trip con il consumo istantaneo (anche con intervento del conce)?!? E attivare altri dati del menu' segreto aggiungendoli sul trip di modo che siano consultabili agendo direttamente sul pulsantino della leva anziche' entrare nel menu' segreto? Scusate la raffica di domande ma sono un neofita e vorrei evitare beghe che mi obblighino a portare l'auto dal conce. Grazie in anticipo.
Io ho provato, arrivo fino al menu della velocitá ma qua mi mostra 000 e poi mi esce dal menu. Non esiste la possibilitá di impostarlo come una delle funzioni tipo la temperatura o il consumo, cioé di programmarlo per poterci arrivare semplicemente tramite il tasto di comando del computer di bordo. Scusate il mio italiano contorto ma ormai sono 3 anni che parlo solo svedese e inglese.
Nikcoswe purtroppo queste info non sono programmabili dal tasto del computer di bordo, ma sono informazioni contenuta nella centralina odc e serve appunto a controllare dei parametri e valori della vettura, bisogna anche stare attendi a non andare sul menù 21 software reset, con questo menù si resetta il software del cruscotto e lo stesso sarà come morto in quanto è in attesa di essere programmato
