[MB] VENDO KIT BT KUFATEC x BMW SERIE F | BMWpassion forum e blog
Discussione in 'Vendesi "Off-topic"' iniziata da DADEHVK, 27 Aprile 2012.
  1. DADEHVK
    DADEHVK Aspirante Pilota
    23 Settembre 2011
    X3 (F25)
    Ciao a TUTTI!
    Vendo quanto in oggetto, NUOVO, MAI INSTALLATO, APERTA LA SCATOLA SOLO x CONTROLLARE IL CONTENUTO
    FATTURA (verra inclusa nella scatola) data 14.02.2012 spedito a me il 15.03.2012
    PREZZO 200 EURO SPEDIZIONE CON PACCO CELERE 3 INCLUSA!!
    LEGGETE BELE LA DESCRIZIONE ECHIEDETE SE AVETE DUBBI!!
    Info prese direttamente dal sito del produttore www.kufatec.de
    Kufatec Bluetooth hands free kit FISCON version "Pro" BMW
    After installation you need to code the vehicle by using diagnostic interface article-ID 39038
    In case of not using item 39038 we do not guaranty for functionality
    Suitable for BMW F-series vehicles:
    1er - F20
    5er - F10, F11
    5er GT - F07
    6er - F12, F13
    7er - F01, F02, F03, F04
    X3 - F25
    Suitable for the following head units:
    CIC Professional
    CIC Business
    Easy Installation - Plug & Play
    Full integration into the vehicle infotainment system
    OEM-menu driven operation by using:
    Oparation panel
    Multifunctional steering wheel (if available)
    Display of telephone information within the central screen of the vehicle
    Voice output through the vehicle speakers - no installation of additional speakers neccessary
    Due to technical limitations of Fiscon phonebook entries may be cut in 3 steps:
    Step1: third phonenumber is removed on entries
    Step2: second phonenumber is removed in phonebook
    Step3: contact name is cut to 8 characters
    Advantages
    Automatic national language - language display of the vehicle infotainment system
    Using of the following telephone functions:
    Phonebook browsing** (limited to 1000 phonebook entries - sub-entries included)
    Access to call lists** (dialed, accepted, missed calls)
    Placing, answering, ending a call
    Volume control
    A2DP** Audiostreaming in order to play music files through the speakers of the vehicle - Only for vehicles without CD-changer
    Display of provider as well as coverage**
    Shows incoming calls with name entries of the phonebook** - Option to accept or decline a call
    Up to 5 mobile phones can be paired
    Alphabetic search of phonebook entries
    Unlimited software updates
    Mute
    Scope of delivery
    Bluetooth interface
    Microphone
    Wiring harness
    Note
    Not suitable for models with identifier - Exx
    **If supported from mobile phone
    Suitable for almost all available Bluetooth mobile phones on the market - Range of functionality always depends on the mobile phone
    There is no need to contact the BMW dealer after fitting. The hands free system will be adjusted automatically while using the diagnostic interface.
    On request the installation is possible by our internal installation service
  2. ABG
    ABG Aspirante Pilota
    10 Aprile 2013
    BMW
    info
    Ciao la tua offerta è ancora valida o hai già venduto il kit?
    Grazie,
    ciao
  3. DADEHVK
    23 Settembre 2011
    X3 (F25)
    Ciao!
    Il KIT lo ho ancora.... fammi sapere se ti interessa o se vuoi + info!
    CIAO DAVIDE
  4. ABG
    10 Aprile 2013
    BMW
    Risolto
    Ciao, grazie per avermi risposto, ma ieri con enorme sorpresa, ritirando la vettura ho scoperto, al contrario di quanto mi era stato detto, che il bluetooth era già installato.
    Grazie comunque,
    CIao,
    Andrea
  5. exeperte68
    exeperte68 Aspirante Pilota
    22 Settembre 2013
    bmw 320
    Ciao il kit è ancora in vendita.
  6. DADEHVK
    23 Settembre 2011
    X3 (F25)
    Ciao! Si il kit è ancora disponibile.
    Fammi sapere se hai bisogno si altre info!
    Ciao Davide
  7. exeperte68
    22 Settembre 2013
    bmw 320
    ciao, bene se completo di tutto lo ritiro quando ti è possibile. Grazie Giuseppe
  8. DADEHVK
    23 Settembre 2011
    X3 (F25)
    Guarda è ancora nella scatola così come mi è arrivato dalla kufatec, per correttezza ti chiedo di leggere bene quello che ho scritto nell'inserzione (preso direttamente dal sito)
    Per il ritiro basta metterci d'accordo, di dove sei?
  9. *Alfonso*
    12.584
    2.113
    30 Marzo 2009
    Diverse...
    Visto l'interesse, al fine di evitare continui UP, invito entrambi a proseguire in PM per gli accordi del caso.
    Grazie.
  10. exeperte68
    22 Settembre 2013
    bmw 320
    Ciao, di Biassono ci possiamo incontrare dalla concessionaria BMW Auto Vanti ex Mariani quando ti è possibile. Grazie
  11. *Alfonso*
    12.584
    2.113
    30 Marzo 2009
    Diverse...
    Gentile @exeperte68 prima di iniziare a postare sul forum e soprattutto prima di ogni richiesta è sempre gradita la presentazione nella sezione Mi presento... io e la mia BMW aprendo una nuova discussione personale.
    Ti invito inoltre, se non lo avessi già fatto, a leggere il
    Regolamento del Forum e le Condizioni di Utilizzo del sito.
    Infine, sempre secondo il regolamento, prima di aprire una nuova discussione è obbligatorio utilizzare la
    funzione Cerca per verificare se l'argomento sia stato già trattato e in caso di esito positivo porre le proprie domande in un thread dedicato già esistente.
    Suggeriamo di visualizzare questo
    tutorial per utilizzare la funzione "Cerca" al massimo delle potenzialità.
    Buon proseguimento su BMWPassion forum.
  12. exeperte68
    22 Settembre 2013
    bmw 320
    Ciao a tutti, mi scuso se non mi sono presentato ieri: sono entrato per caso nel forum perché ero in cerca di un kit Bluetooth per caso o visto che il nostro amico DADEHVK ne possiede uno che fa per la mia BMW320 E 91 quindi mi sono registrato nel forum. Devo ancora capire bene come funziona per non commettere più errori, ringrazio *Alfonso* moderatore per avermelo fatto notare.
