Do It Yourself (DIY) remove E92 Trunk Lid
Discussione in 'BMW Serie 3 E90-E91-E92-E93' iniziata da Tokion, 8 Gennaio 2008.
  1. Tokion
    Tokion Aspirante Pilota
    23 Febbraio 2007
    tokion
    Removing the trunk lid is quite straight forward; just simply remove the screws and bolts and un-plugs all the wires inside the trunk panel.
    http://www.dukedynamics.com/forums/viewtopic.php?f=13&t=22&p=33#p33
    Step1: Remove all 10 "Expanding Rivet"
    Step2: Remove the hidden "Expanding Rivet" inside the trunk handle.
    Step3: Twist the "STOP BUFFER" counter clock wise
    Step4: Un-hook the "Handle F Emergency unlocking" plastic by pressing gently to the tap.
    Step5: Remove the trunk lid trim panel and pull it on a side.
    Step6: This is what you see after you removed the "Trim Lid Trim Panel"
    Step7: Remove the bolt from the "REAR LIGHT in Trunk Lid" Left Side.
    Step8: Do the same thing for the Right side
    Remove the bolt from the "REAR LIGHT in Trunk Lid" Right Side.
    Step9: Un-screw the "Torx-Bolt" to remove the trunk lid lock.
    Step10: Remove the bolts; you might need a second person to help you to hold the trunk.
    I will post more steps later on.​
