BMW 535d
Discussione in 'BMW Serie 5 E60-E61' iniziata da Gabri343, 17 Febbraio 2004.
  1. Gabri343
    Gabri343 Amministratore Delegato BMW
    4.127
    2 Giugno 2003
    The new BMW 535d Saloon and Touring
    Featuring BMW’s award-winning 3.0-litre diesel engine, the all-new BMW 535d offers a first for a BMW diesel car engine – two-stage turbocharging. The new engine delivers a maximum output of 272 bhp and, more importantly, 560 Nm of torque at 2,000 rpm, with 500 Nm available at just 1,500 rpm. This propels the new BMW 535d from zero to 62 mph in just 6.6 seconds. To put this into perspective, the current 530d, itself no slouch, produces 218 bhp while the E39 M5 offered 500 Nm of torque.
    Two-stage turbocharging resolves the conflict of ‘turbo lag’ when accelerating hard at low engine speed and increases the availability of power at higher engine revs. The first turbocharger provides an almost instant kick of turbo pressure at low engine speeds while the second turbocharger cuts in at higher engine speeds to boost power throughout the higher rev range. The new turbo layout also extends the engine rev range by 500 rpm over the BMW 530d, to a maximum of 4,800 rpm. Even with such performance, exhaust emissions are not compromised, since the 535d has a particulate filter and is fully compliant with EU4 regulations.
  2. mercenari
    mercenari Secondo Pilota
    608
    31 Marzo 2003
    Re: BMW 535d
    :question: cioè?
  3. freeze
    6.684
    44
    4 Gennaio 2004
    BMW 330Ci Cabrio e46
    cavolo che favola... se fino ad ora BMW ha fatto motori seri... adesso cominciamo a divertirci... praticamente l'equivalente del Vanos per il turbo... :mrgreen: :mrgreen: :mrgreen:
  4. RALLYMAN
    15.797
    170
    11 Febbraio 2004
    335xi E90 M-Sport+530d Futura
    In pratica, una sorta di 535d biturbo... Uazz! :angel:
  5. freeze
    6.684
    44
    4 Gennaio 2004
    Si ma il primo turbo entra a pochi giri probabilmente è piccolo e inizia a girare presto per dare potenza ai bassi poi quando arriva più aria entra in funzione il secondo che sarà una sberla e ti da una botta ancora più grossa: risultato ottima ripresa dai bassi e grande tiro in allungo...
    Praticamente una bomba atomica...
  6. freeze
    6.684
    44
    4 Gennaio 2004
    se poi lo mettono anche sulla serie 3 allora sono fuochi d'artificio...
  7. RALLYMAN
    15.797
    170
    11 Febbraio 2004
    Non so perchè, ma mi viene in mente una certa Delta S4... :lol: :lol: :lol:
  8. Pislui
    Pislui Collaudatore
    391
    4 Marzo 2004
    328 CI - GPL
    Re: BMW 535d
    Cito:
    A partire dal prossimo autunno, BMW segnerà un altro passo importante nell'evoluzione tecnologica dei motori a gasolio con l'introduzione del turbocompressore multi-stadio nelle nuove BMW 535d berlina e Touring,
    La potenza ottenuta in rapporto alla cilindrata di 3000cc è praticamente un record per l'industria automobilistica. Sia la berlina che la Touring sviluppano 272 CV; la loro coppia massima di 560 Nm è disponibile a 2.000 giri, ma oltre 500 Nm sono già disponibili a partire da 1.500 giri!
    Per adottare il turbocompressore bistadio, finora conosciuto soltanto nei sistemi di propulsione marini, gli ingegneri della Casa bavarese hanno dovuto ovviare all'incompatibilità tra il "ritardo della turbina" nelle accelerazioni dai bassi regimi e la disponibilità di grandi riserve di potenza su percorsi veloci come le autostrade.
    Dopo aver compresso l'aria di aspirazione nella prima turbina, la tecnologia multi-stadio BMW la comprime ulteriormente in una seconda turbina. L'aria aspirata attraversa quindi un intercooler alla pressione massima di 2,85 bar, per immettersi direttamente nelle camere di scoppio, dove l'accresciuta pressione nei cilindri assicura un notevole aumento di potenza. Per un motore 3 litri, come quello della BMW 530d, già riconosciuto come propulsore molto prestazionale con la sua potenza massima di 160 kW/218 CV, l'aumento di potenza è di ben 54 CV.
    Da primato le prestazioni dichiarate: la BMW 535d accelera da 0 a 100 km/h in appena 6,6 secondi.
    L'eccezionale spontaneità nella risposta del motore viene assicurata dal secondo stadio di compressione, dal momento che l'elevata efficienza così ottenuta garantisce un rapido aumento della pressione nella turbina già dai bassi regimi. Quindi, una volta che il motore ha raggiunto velocità maggiori, il secondo stadio viene attivato per fornire un ulteriore aumento di potenza fino al livello massimo.
    Ciò aumenta la gamma di regimi utili del motore, rispetto ai diesel turbo generalmente usati oggi, di 500 giri/min. fino ad un massimo di 4.800 giri/min., contribuendo così a evidenziare il carattere sportivo di questo motore.
    La tecnologia multi-stadio BMW verrà offerta esclusivamente con trasmissioni automatiche a sei velocità e con freni ad alte prestazioni.
    Un ulteriore punto di merito è costituito dall'introduzione di un filtro per il particolato montato di serie sulla 535d che ovviamente soddisfa già gli standard Euro 4 sulle emissioni.
    Il prezzo di questa straordinaria vettura sarà annunciato poco prima dell'introduzione sul mercato, prevista per l'autunno 2004.
  9. ///M3
    ///M3 Presidente Onorario BMW
    15.764
    650
    9 Aprile 2004
    E46 coupe & E36 vert
    La Lancia Delta S4 non aveva un biturbo, ma un un turbo tradizionale che lavorava in coppia con un compressore volumetrico.
    Cmq il 535d della BMW non è un biturbo, ma un turbo multistadio con le 2 trubine che lavorano in serie (e non in parallelo, come per gli altri motori attualmente in commercio, dove ad esempio per un 6 cilindri una turbina ne rifornisce 3 mentre degli altri 3 se ne occupa l'altra turbina) e così facendo permettono di annullare il famoso quanto fastidioso turbo-lag (in termini di erogazione, invece per l'adrenalina questo è una vera e propria botta di vita), cioè il ritardo di entrata in funzionamento del turbo in un primo momento per poi seguire una spinta di potenza quando questo è in pressione.
  10. RALLYMAN
    15.797
    170
    11 Febbraio 2004
    Ehi, guarda che lo so benissimo!
    Proprio a me lo vieni a dire.....
    Le Delta sono state il mio pane per anni, ehehehehehehe :lol: :mrgreen: :lol:
  11. ///M3
    15.764
    650
    9 Aprile 2004
    Scusa RALLYMAN, non volevo fare il sapientino :redface: :rolleyes:
    ma da come era messa la frase si poteva cadere in errore...
  12. RALLYMAN
    15.797
    170
    11 Febbraio 2004
    Ma no, figurati.
    Il mio era solo un pensiero.
    Sai, a volte tra lo scrivere e l'interpretare.....
    Non ti preoccupare, nessun problema.
    Non sono mica così permaloso, ancora non mi offendo per cosi poco..... :lol: :mrgreen: :lol:
    Ciao.
  13. aristoweb
    aristoweb Presidente Onorario BMW
    7.393
    19 Luglio 2003
    BMW M3 Coupé E92
    Sbaglio ho il 535d sarà solo con cambio automatico?
  14. eltractor
    eltractor Collaudatore
    414
    1 Novembre 2003
    BMW 330cd e46
    si,uscirà solamente con l'automatico :cry: :cry:
  15. Davide
    25.219
    484
    20 Aprile 2004
    130i E87
    no l'automatico no.
    se lo mettono sul serie 3 (4) con l'automatico e uno si vuole divertire a scodare come fa? quando sei in derapata e devi tenere la marcia inserita quei bastardi degli automatici ti mettono sempre il rapporto superiore :evil: :evil: :evil: :evil:
  16. aristoweb
    7.393
    19 Luglio 2003
    BMW M3 Coupé E92
    Sarà perchè la trasmissione non ce la fa a reggere la coppia?
  17. RALLYMAN
    15.797
    170
    11 Febbraio 2004
    Può darsi, ma io "odio" gli automatici!!!..... :evil: :evil: :evil:
  18. aristoweb
    7.393
    19 Luglio 2003
    BMW M3 Coupé E92
    anche io! :lol:
  19. Capo
    Capo Primo Pilota
    1.286
    14
    20 Ottobre 2003
    330cd
    taci una volta con la mia ero li li per stamparmi!!!!!!!
    Poi ci fai la abitudine, conosci il vizio e sai come agire....
    credimi anche con l'auto derapi che e un piacere
  20. M330d
    M330d Secondo Pilota
    903
    6 Novembre 2003
    Vero :eek: vero :wink: !!!
    Ciao!
    Chi i FARI mi rivolge,
    Una NUBE lo avvolge. :evil:
