Richiamo per 500'000 di veicoli per un difetto al VANOS dei propulsori 6 cilindri | BMWpassion forum e blog
Discussione in 'Segnalazione RICHIAMI' iniziata da giacomo, 11 Aprile 2014.
  1. giacomo
    13.853
    948
    4 Marzo 2004
    Renault Clio
    BMW of North America said it is voluntarily recalling about 156,137 2010-2012 model-year vehicles in the United States because of a potential defect with the variable camshaft timing.
    BMW says the recall will address a problem with the variable camshaft timing, also known as VANOS, which could reduce engine power and further cause damage if not repaired.
    “The unit rotates the intake or exhaust camshaft in order to alter the timing of the lift of the respective intake or exhaust valves,” a BMW spokesman said for Automotive News.
    In a statement, BMW said that “in very rare cases, the bolts holding the variable camshaft timing unit housing may become loose or, in extreme cases, break.”
    Should that happen, the “check engine” or “service engine soon” light comes on followed by the display of a “check control message.”
    “If ignored, the problem can become progressively worse, eventually leading to no start conditions, stalling and engine damage,” BMW said.
    The affected models are:
    • 2010-12 1 series
    • 2010-12 3 series
    • 2010-2012 5 series
    • 2010-12 5 series Gran Turismo
    • 2012 6 series
    • 2010-2012 X3
    • 2010-12 X5
    • 2010-12 X6
    • 2010-12 Z4
  2. beckervdo
    4.236
    Kia Sportage HEV 2023 / Mazda 2 2010
    Via BMWNews.it
  3. Psaumide
    Psaumide Kartista
    87
    29
    26 Aprile 2014
    BMW 520d G30, precedente BMW 523i F10
    Sembra che in Italia ne sappiano ancora poco. Ho appena fatto un tagliando su una 523i N53 e mi hanno sostituito candele e bobine per un richiamo generale su quest'ultime, ma niente a proposito del Vanos
  4. Carlo75
    Carlo75 Aspirante Pilota
    21
    16 Aprile 2010
    335i XDrive Touring
    Ciao a tutti, sono stato proprio oggi a prenotare il tagliando...e mi hanno informato di questo richiamo. La loro circolare interna è datata 13/6, quindi recentissima!
    Speriamo facciano un buon lavoro, mi è stato detto che serviranno circa 6 ore di "intervento"...:eek:
  5. beckervdo
    4.236
    Che velocità...dall'11 Aprile al 13 Giugno.
