Vendo Amplificatore Kenwood
Discussione in 'Forum generale BMW' iniziata da p.gab, 1 Settembre 2003.
  1. p.gab
    p.gab Kartista
    110
    22 Luglio 2003
    Vendo amplificatore Kenwood kac-646x a 70 euro, queste sono le caratteristiche:
    GENERAL FEATURES
    - 4, 3, or 2 Channels of Amplification
    - Power MOSFET Switching Power Supply
    POWER RATINGS
    - Bridged Power Output at 14.4V (1kHz, 0.8% THD): 70 Watts x 2
    - Maximum Output Power (Bridged): 140 Watts x 2
    - Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 35 Watts x 4
    - Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 25 Watts x 4
    AUDIO FEATURES
    - Ground Isolation Circuit
    - Input Selector: AB/A (Independent)
    - Quiet Turn-On
    - RCA Audio Inputs: Gold-Plated
    - RCA Line Outputs: Gold-Plated
    - Signal-to-Noise Ratio: 100dB
    - Speaker Connectors: Gold-Plated, Screw-Type
    - Speaker Level Input Terminals: Gold-Plated, Screw-Type
    - Speaker Relay Protection
    - Stereo, Mono, or Tri-Mode Operation
    POWER SUPPLY FEATURES
    - 2-Ohm Stable
    - Copper EI Core Transformer
    - Large Toroidal Noise Suppression Filter
    - Power Indicator
    - Power Input Terminals: Gold-Plated, Screw-Type
    GENERAL SPECIFICATIONS
    - Current Consumption (Maximum): 22A
    - Operating Voltage: 14.4V (11V - 16 V allowable)
    AUDIO SPECIFICATIONS
    - Damping Factor: >100
    - Frequency Response: 10Hz - 45kHz (+0dB, -1dB)
    - High-Pass Filter Frequency: Off/150Hz, 12dB per Octave
    - Input Impedance: 10kOhms
    - Input Sensitivity: 0.2V - 4V
    - Low-Pass Filter Frequency: Off/80Hz, 12dB per Octave
    POWER RATINGS
    - Bridged Power Output at 14.4V: 70 Watts x 2 (less than 0.8% THD, 1kHz)
    - Maximum Output Power: 140 Watts x 2
    - Power Output at 2 Ohms, at 14.4V: 35 Watts x 4 (less than 0.8% THD, 1kHz)
    - Power Output at 4 Ohms, at 14.4V: 25 Watts x 4 (less than 0.08% THD, 20Hz - 20kHz)
